How do I determine the current version of LastPass Universal Proxy v4.x on Windows?
Problem
I do not know which version of LastPass Universal Proxy I am using.
Remedy:
- Open PowerShell and execute the following command:
uproxy -version
The following is an example system output:
PS C:\Users\test> uproxy -version LastPass Universal Proxy version: 2.2.0
- If you cannot execute the previous command, go to the bin folder of the base directory (by default, C:\Program Files\LastPass\Universal Proxy\bin, check the version.bat file.
- If you cannot find the version.bat file, it means you have a version prior to 1.1.0.
If you can find the version.bat file, run the file using the command line. As a result, the following message appears: LastPass Universal Proxy version: <version number>.
The <version number> will show the version of the product.
