Re-enable push notifications for a site using the LastPass Authenticator app
    If you disabled push notifications for the LastPass Authenticator for certain sites by adding the sites as Never URLs, you can delete the Never URLs to re-enable push notifications at any time.
    3. Select the Never URLs tab.
    4. Under the "Never Ask About TOTP-to-Push" section, click the Delete icon in the Action column for the sites in which you want to re-enable push notifications.
      Note: If desired, you can also delete any entries where no URL or domain is specified.
    Results: The next time you visit the site(s), you will be prompted to authenticate with a push notification via the LastPass Authenticator.
