How do I include a password in the security score calculation?
    You can reinclude passwords in your security score calculation.
    About this task: You can reinclude a password in your security score calculation if you have excluded it previously on the Password Security page of the Security Dashboard.
    1. Log in and access the LastPass Security Dashboard by doing either of the following:
      • While logged in to LastPass, click the active LastPass icon active LastPass icon in your web browser toolbar, then select Security Dashboard in the menu.
      • Log in at https://lastpass.com/?ac=1 with your email address and master password, then select Security Dashboard in the left navigation.
    2. Select View passwords.
    3. On the Password security page, select More options for the password that you want to include.
    4. Select Include in security score.​
    Results: The password is reincluded in the security score calculation.
