I don't have a smartphone, how can I use multifactor authentication with LastPass?
LastPass supports multifactor authentication in various forms that do not require a smartphone.
The following multifactor options are supported:
- Set Up LastPass to Use the LastPass Authenticator app (phone call or YubiKey)
- Use Duo Security Authentication (phone call or security key)
- Use YubiKey Multifactor Authentication (security key)
