I just upgraded my LastPass plan but my vault is blank, what should I do?
After you upgrade your plan from LastPass Free to a paid subscription plan, you will need to manually re-sync your vault in order to restore its contents so your vault can be viewed from both device types.
If you're seeing a blank vault on your mobile device
If you're seeing a blank vault on your desktop
Restore your vault contents when accessing LastPass from a computer.
- Destroy all active sessions using the LastPass browser extension or by logging in to your online vault (learn how here).
- Refresh your Vault to manually sync your data by following instructions on the device where your vault is blank:
- Clear your local cache on the device where your vault is blank (instructions will vary, based on your device).
- Log out and log back in to LastPass.
Your LastPass account has been synced with our servers, and your vault contents is now restored for your device.
