I lost my phone! How do I disable multifactor authentication for LastPass?
If your phone number has changed or the mobile device you used for authentication is lost, you should immediately disable multifactor authentication for your device (via email) so that you can log in and access your LastPass account.
Attention: The LastPass Authenticator cannot be disabled via email. To access your account, you can use SMS account recovery to log in, then disable multifactor authentication for your device. If SMS recovery had not previously been set up, please contactLastPass Support by navigating directly to this article and selecting a contact option at the bottom.
To disable multifactor authentication for supported authenticators, do the following:
You can now log in to LastPass with your email address and
master password, and will not be prompted to authenticate.
What to do next: The following options are recommended once you have logged back in to LastPass:
- If your device was lost or stolen, it is strongly recommended that you change your master password – learn how here.
- You can re-enable multifactor authentication for a new device – learn how here.
