JIRA App Integration
- Log in and access the LastPass new Admin Console by doing either of the following:
in your web browser toolbar, then select Admin Console in the menu.
- Log in at https://admin.lastpass.com with your admin email address and master password.
- Go to Applications > SSO apps.
- Select Add app in the upper-right navigation (or Add your first SSO app if you're adding your first app).
- Search for and select your app from the catalog (or Add an unlisted app if you can't find your app).
- Click Continue, and you are taken to the Set up LastPass section of the app configuration.
Name in LastPass Value Entity ID https://identity.lastpass.com
SSO Endpoint https://identity.lastpass.com/SAML/SSOService
Logout URL https://identity.lastpass.com/Login/Logout
Certificate fingerprint Provided in the Set up app section of the SSO app. If needed, download the LastPass certificate in PEM, DER, or Download metadata (XML) format. Certificate fingerprint (SHA256) Certificate (PEM) - For the next steps, open a new web browser window or tab. Go to the app's settings to enable single sign-on, and make sure your app recognizes LastPass as the Identity Provider.
Part 2 - App Configuration
Open a new tab on your browser and log into your Jira account. Then,
follow the instructions to configure SAML SSO for Jira.
Part 3 - Finalize the JIRA SSO App Configuration
- Return to the LastPass new Admin Console.
- Back on the Configure app page in the LastPass Admin Console (from Part 1), locate Set up LastPass.
- LastPass needs to know the app’s URI to the Assertion Consumer Service (ACS) to be able to authenticate users. This is provided by your SSO app.
- ACS
- The URL to which LastPass sends authentication assertions after authenticating a user. It may also be known as Post-Back URL, Reply URL, Single Sign-On URL, or Service Provider URL.
- Step-up authentication
- Enable this setting if you want to force users to confirm their identity using the LastPass Authenticator app upon each login to this SSO app (i.e., LastPass MFA).
- Optional: If desired, select Advanced settings to add any of the following additional customizations:
Name in LastPass Description/Value Entity ID This is the Metadata URL of the Service Provider (also known as the Issuer ID or App ID for your app) Nickname The name of the app how it appears in the Admin Console (and Cloud Apps, if your users have a LastPass password management vault) Role Custom role that you created to organize users and the permissions assigned to them Identity Provider (LastPass) This is the URL of the identity provider, which is LastPass: https://identity.lastpass.com
Relay State URL to which the service provider redirects the user after processing the SAML response Identifier These settings will depend on the app you're configuring – please refer to the SSO app's documentation, then select one of the following: - Email (default)
- Secondary Email
- User ID
- Groups
- Roles
- Custom
SAML signature method Select one of the following, based on your desired encryption key length: - SHA1 (uses 160-bit hash)
- SHA256 (uses 256-bit hash)
Signing and encryption Make your desired selections from the following: - Sign assertion
- Encrypt assertion
- Sign request
- Sign response
Upload partner certificate Select the partner certificate you saved locally (if applicable) Custom attributes To add more custom attributes, select Add SAML attribute and choose from the following options: - Secondary Email
- User ID
- Groups
- Roles
- Custom (associated with the SSO app)
- Click Save & assign users > Users, groups & roles to begin making your selections.
- Search for and select your desired users, groups, and/or roles, then click Assign.
- Click Save & continue > Finish.
