LastPass Admin Toolkit: LastPass Passwordless Authentication & Workstation Login
Passwordless authentication is an adaptive authentication feature of the LastPass Authenticator for LastPass Business users that supports using biometrics (face or fingerprint recognition and PIN Code) instead of a password for authentication. Users of passwordless authentication can use the LastPass Authenticator to verify their login for their workstations and/or websites that they sign in to and use daily.
Passwordless authentication is a feature that allows users to utilize stored biometrics (i.e., face recognition or fingerprint identification) on their mobile device via the LastPass Authenticator instead of entering a password to authenticate. Passwordless authentication can be leveraged in LastPass when logging in to SSO apps and/or workstations.
Admin Resources
- What is passwordless authentication in LastPass? – View a full overview of passwordless authentication, including what it is, who can use it, and how it is used.
- Passwordless authentication policies – The following policies are available for LastPass admins to set up in order for users to authenticate using passwordless authentication (i.e., being prompted for biometric authentication via the LastPass Authenticator app):
- Passwordless authentication policies (required)
- Passwordless authentication access policies (optional)
End User Resources
- How do I activate passwordless authentication? – View step-by-step instructions for downloading the LastPass Authenticator on your mobile device and activating passwordless authentication.
- How do I manage passwordless authentication settings in the LastPass Authenticator app? – Learn about the authentication settings that you can view and manage within the LastPass Authenticator.
- How do I use passwordless authentication when my device is offline? – If you are not connected to the Internet (for example, in Airplane Mode), learn how to use the passwordless authentication while offline.
- Passwordless Authentication Troubleshooting for Users – View answers to our most frequently asked troubleshooting questions.
Workstation Login
Workstation Login for LastPass enables users to log in to their workstations, or work computers, using biometric authentication (face recognition or fingerprint identification) via the LastPass Authenticator.
Admin Resources
- Workstation Login Overview – Learn about what Workstation Login is and the benefits of using it.
- LastPass Workstation Login FAQs – Review a guide of frequently asked questions all about Workstation Login.
- Setting Up Workstation Login for Distribution (Windows) – View step-by-step instructions for preparing Workstation Login as an admin so that you can distribute it to your Windows workstation users.
- Setting Up Workstation Login for Distribution (Mac) – View step-by-step instructions for preparing Workstation Login as an admin so that you can distribute it to your Mac workstation users.
- Setting Up Policies for Workstation Login – The following policies are available for LastPass admins to set up in order for users to utilize Workstation Login:
- Workstation Login policies (required)
- What are the differences between Workstation Login and Workstation MFA in LastPass Business? - Follow this article to get a better understanding between the key differences.
End User Resources
- Complete Setup Guide for End Users – View resources for supporting your end users for when they set up and transition to using Workstation Login on their Windows or macOS workstations.
- LastPass Workstation Login Setup Guide
- LastPass Workstation Login Setup Video (0:27)
