Use the LastPass Authenticator
The LastPass Authenticator is a multifactor authentication app for iOS and Android that can be used for authentication when accessing your LastPass vault, assigned SSO apps, third-party apps or websites, and/or your LastPass workstation.
Features and compatibility
The LastPass Authenticator supports various different authentication methods:
- One-tap push notifications
- Time based 6-digit codes (TOTP codes)
- SMS passcode (6-digit codes sent via text message)
- Phone call via Call Me (available only when the LastPass Authenticator is enabled as a multifactor option to protect your LastPass vault – learn more)
LastPass Authenticator is also TOTP compliant, meaning it is compatible with all apps and websites that support Google Authenticator. That means you can conveniently manage multifactor authentication for multiple services, all from LastPass.
