LastPass for Android
LastPass for Android is an application that will allow you to carry your LastPass data around with you. Once you install and log in to the app, you can set up Fingerprint Authentication, enable and use autofill, add and manage passwords, secure notes, and items in your vault, use the Sharing Center, or change your Settings.
