Manage LastPass SSO Apps
LastPass SSO apps are common online tools used within a company for which a LastPass Business admin has set up a single sign-on integration. This allows users to sign in to LastPass and launch any of their apps without having to re-enter their credentials for those apps. You can add or manage your app's settings and/or users, groups, and roles assigned to your apps.
Manage SSO app settings
You have selected your desired configurations for your selected SSO app.
Assign test users to your app
If you have not yet assigned a user to your SSO app, you can assign a test user to your app.
Manage users & groups assigned to SSO apps
- Go to .
- Under Applications, use the Search field to locate your desired app.
- Select the desired application.
- In the Configure app window, click Save & edit users.
- In the Users, groups & roles window:
- Click Assign users, groups & roles to assign users to your application.
- To unassign users, under Users, Groups or Roles, select the user you would like to unassign and click Unassign.
- Click Save & continue.
- Click Finish.
You have assigned your desired users and/or groups to your selected SSO app.
