Manage the Allowance of Tor Networks
    By default, LastPass restricts access from known Tor entry points.
    About this task:
    To change this behavior (or to re-enable this restriction), do the following:
    3. On the General tab, click Show Advanced Settings.
    4. In the Security section, check or uncheck the box for the Prohibit logins from Tor networks setting.
      Tor Networks settings in Account Settings
    5. When prompted, enter your master password then click Continue.
    Results: You have updated your Tor network settings.
