How do I manage my Trusted Devices in Account Settings?
Once you have set up multifactor authentication for your account, you can choose to "trust" a device when you log in to LastPass, which will skip the multifactor authentication prompt for 30 days for your device. Once trusted, you can rename, revoke trust, or delete a trusted device.
Trusting a device is only recommended for personal devices that are only used by you, and you follow general security best practices (e.g., run anti-virus service, avoid accessing suspicious links, etc.).
Trust a device
You can trust an individual device for 30 days, which will skip multifactor authentication prompts for the specific device when you log in to LastPass. You will still be prompted for multifactor authentication when accessing LastPass on other devices.
- Using the device you want to trust, log in to LastPass using the website, web browser extension, mobile app, or desktop app.
- When prompted by multifactor authentication, enable the Trust this <device> for 30 days setting.
Troubleshooting: If you are not prompted for multifactor authentication, it means either you have already set this device as trusted or you have not enabled multifactor authentication.
- Optional: Enter a name for your trusted device; if you don't enter a name, LastPass will list the device as the name of the computer, mobile device, or web browser you're using.
- Complete the steps for multifactor authentication.
Rename a trusted device
To easily identify each of your trusted devices, you can rename them at any time.
Revoke trust for a trusted device
You can revoke trust temporarily for a particular device so that it prompts you for multifactor authentication within the 30-day trust window. The device will remain listed, and you can re-enable trust at any time within the 30-day trust period.
Delete a trusted device
You can end the 30-day trust period for a particular device by deleting it. This will remove it from your Trusted Devices list and prompt you for multifactor authentication when you log in to LastPass from it.
