Use the Microsoft Authenticator
Microsoft Authenticator is a multifactor app for mobile devices that generates time-based codes used during the Two-Step Verification process.
Features and compatibility
- One-tap push notification and 6-digit SMS code authentication options are not supported when using this mobile authenticator
- If you have a LastPass Teams or LastPass Business account, the ability to perform these actions may be limited or prohibited due to policies enabled by your LastPass admin.
For LastPass admins, it is recommended that you complete the steps for enabling multifactor authentication in the Admin Console.
- If you are currently using the Google Authenticator and want to use the Microsoft Authenticator instead, view migration instructions applicable to your role in LastPass:
