Oracle Hyperion EPM App Integration
    About this task:
      Name in LastPass Value
      Entity ID
      https://identity.lastpass.com
      SSO Endpoint
      Logout URL
      Certificate (PEM)
    Part 2 - App Configuration
    About this task: Open a new tab on your browser and log in to your Oracle account. Then, follow the instructions to configure the SAML SSO for Oracle Hyperion EPM.
    Part 3 - Finalize the Oracle Hyperion EPM SSO App Configuration
      ACS
    4. Select Advanced settings.
      • Email (default)
      • Secondary Email
      • User ID
      • Groups
      • Roles
      • Custom
      • Sign assertion
      • Encrypt assertion
      • Sign request
      • Sign response
      • Email
      • Secondary Email
      • User ID
      • Groups
      • Roles
