Manage Folders within Your LastPass Vault
To organize your vault so you can easily find what you're looking for, you can create folders and/or sub-folders, then move your items into them to be stored. You can also delete and/or purge a folder containing items.
Create a Folder
and select Open My Vault.
- Select All Items or your desired item category in the left navigation.
- Hover over the Add icon
in the bottom-right corner, then click Add New Folder.
- Enter a new Folder Name, or if you want it to be created as a sub-folder under an existing folder, check the box to enable Add as a sub-folder under:, then use drop-down menu to select your desired parent folder.
- Click Save when finished.
Create a sub-folder
- From within your LastPass vault, select All Items in the left navigation.
- Right-click on your desired folder, then select Create Sub-Folder.
- Enter a name in the Folder field for your sub-folder.
- Click Save.
Move an item into a folder
You can move a form fill item into a folder, or transfer an item from one folder into a different folder.
Delete a folder
Deleting a folder will also delete all items within that folder. Additionally, folders that do not contain any items are automatically purged when they are deleted.
- Right-click on the name of your folder, then select Delete Folder.
- Click Yes to confirm.
Purge a folder
Folders that do not contain any items are automatically purged when they are deleted. For folders that contain items, you can purge them to permanently delete by doing the following:
- Click Advanced Options in the left navigation.
- Select View deleted items, then choose from the following options.
- Click Purge All in the top navigation to permanently delete all items listed.
- Select individual folders, then use the Actions drop-down menu and select Purge.
Rename a folder
- Right-click on the name of a folder, then select Rename Folder.
- Enter the new name of the folder.
- Optional: To add the folder as a sub-folder, select the option Add as a subfolder here. Using the drop-down menu, select which folder to put it under.
- Optional: To remove the folder as a sub-folder, uncheck the option Add as a subfolder here. This will put the sub-folder at the top level.
- Click Save.
