Palo Alto Network VPN configuration for the LastPass Universal Proxy LDAPS protocol
Add the LDAP server profile
In the Palo Alto Network, go to
and Add a new LDAP Server Profile.
- In the Server List group box, click Add and set the following:
- Enter a Name to identify the server.
- Enter the LDAP Server IP address or FQDN.
- Enter a Port number, default is 636 for authentication.
- In the Server Settings group box, select your LDAP server Type.
- Set the Base DN.
- Set the Bind DN.
- Set the Password.
- Set the Bind Timeout.
- Check the Require SSL/TLS secured connection checkbox.
- Click OK.
Assign the LDAP server profile to an authentication profile
Results: You have now configured LDAPS authentication for your Palo Alto VPN.
