Palo Alto Networks VPN
Set up a Palo Alto Networks VPN SSO app integration so that your users can sign into this app using the same credentials that they use for LastPass.
- Log in and access the LastPass new Admin Console by doing either of the following:
in your web browser toolbar, then select Admin Console in the menu.
- Log in at https://admin.lastpass.com with your admin email address and master password.
- Go to Applications > SSO apps.
- Select Add app in the upper-right navigation (or Add your first SSO app if you're adding your first app).
- Search for and select your app from the catalog (or Add an unlisted app if you can't find your app).
- Click Continue, and you are taken to the Set up LastPass section of the app configuration.
Name in LastPass Value Entity ID https://identity.lastpass.com
SSO Endpoint https://identity.lastpass.com/SAML/SSOService
Logout URL https://identity.lastpass.com/Login/Logout
Certificate fingerprint Provided in the Set up app section of the SSO app. If needed, download the LastPass certificate in PEM, DER, or Download metadata (XML) format. Certificate fingerprint (SHA256) Certificate (PEM) - For the next steps, open a new web browser window or tab. Go to the app's settings to enable single sign-on, and make sure your app recognizes LastPass as the Identity Provider.
Part 2 - Configure the app in Palo Alto Networks VPN
For detailed instructions, please see
Palo Alto Networks VPN documentation.
- Log into the admin console of your VPN server and go to Device > Server Profiles > SAML > Identity Provider > Import.
- Set up a Profile Name and import the LastPass metadata file (downloaded in Part 1) by selecting Browse... and selecting the metadata file that you saved, then click OK to save changes.
- Next, create a new Authentication Profile. Navigate to Device > Authentication Profile and click Add.
- Select your authentication profile name. Select SAML from the Type options and select the LastPass identity provider name that you created in the IdP Server Profile.
- Click on the Advanced tab and select all users or a list of users in the Allow List. Click Ok to save changes.
- Next, switch to the new authentication profile on your GlobalProtect Portals and Gateways. Navigate to Network > GlobalProtect > Portals, select the portal you'd like to update, click on the Authentication tab, and select the authentication profile that you created.
- Open Network > GlobalProtect > Gateways, select the portal you'd like to update, click on the Authentication tab, and select the authentication profile recently created.
Note: For more about information about the Palo Alto Network VPN SAML setup, visit Palo Alto Network SAML setup page.
Result: Finalize the Palo Alto Network VPN configuration in LastPass by performing the steps in finalizing the Palo Alto Network VPN configuration.
Part 3 - Finalize the Palo Alto Network VPN configuration
- Return to the LastPass new Admin Console.
- Back on the Configure app page in the LastPass Admin Console (from Part 1), locate Set up LastPass.
- LastPass needs to know the app’s URI to the Assertion Consumer Service (ACS) to be able to authenticate users. This is provided by your SSO app.
- ACS
- The URL to which LastPass sends authentication assertions after authenticating a user. It may also be known as Post-Back URL, Reply URL, Single Sign-On URL, or Service Provider URL.
- Step-up authentication
- Enable this setting if you want to force users to confirm their identity using the LastPass Authenticator app upon each login to this SSO app (i.e., LastPass MFA).
- Optional: If desired, select Advanced settings to add any of the following additional customizations:
Name in LastPass Description/Value Entity ID This is the Metadata URL of the Service Provider (also known as the Issuer ID or App ID for your app) Nickname The name of the app how it appears in the Admin Console (and Cloud Apps, if your users have a LastPass password management vault) Role Custom role that you created to organize users and the permissions assigned to them Identity Provider (LastPass) This is the URL of the identity provider, which is LastPass: https://identity.lastpass.com
Relay State URL to which the service provider redirects the user after processing the SAML response Identifier These settings will depend on the app you're configuring – please refer to the SSO app's documentation, then select one of the following: - Email (default)
- Secondary Email
- User ID
- Groups
- Roles
- Custom
SAML signature method Select one of the following, based on your desired encryption key length: - SHA1 (uses 160-bit hash)
- SHA256 (uses 256-bit hash)
Signing and encryption Make your desired selections from the following: - Sign assertion
- Encrypt assertion
- Sign request
- Sign response
Upload partner certificate Select the partner certificate you saved locally (if applicable) Custom attributes To add more custom attributes, select Add SAML attribute and choose from the following options: - Secondary Email
- User ID
- Groups
- Roles
- Custom (associated with the SSO app)
- Click Save & assign users > Users, groups & roles to begin making your selections.
- Click Save & continue > Finish.
