Passwordless Login for Vault on Oculus
You can enable passwordless login for vault on your Oculus device for easy vault sign-in, which allows you to use a push notification (or any other available authentication method) via the LastPass Authenticator app instead of manually entering your master password.
Step #1: Enable your vault to use the LastPass Authenticator app
First, you will need to enable your LastPass vault to use the LastPass Authenticator app as the only multifactor authentication option. This will grant you the ability to set up passwordless login on your Oculus device.
Complete all the steps in these instructions, then return to this article and proceed to the next step.
Step #2: Enable passwordless login for Oculus
Next, enable passwordless login by using the Meta Quest Browser app.
Notice: Setting up passwordless login directly from the LastPass app for Oculus is not supported, and can only be done using the Meta Quest Browser app.
Results: You have enabled
passwordless login for your vault from this specific device.
Step #3: Use passwordless login on Oculus
Now that you're all set up, you can use passwordless login via the LastPass app for Oculus going forward.
Before you begin: You must install the LastPass app for Oculus from the Meta Quest Store before proceeding.
Results: You have used
LastPass Authenticator app to log in to your LastPass vault on your Oculus device.
