PowerShell scripts in LastPass Universal Proxy v4.x
    We provide PowerShell scripts as a unified interface to ease the management of LastPass Universal Proxy. The administrator can configure Universal Proxy, start/stop the Windows service, perform diagnostics, and so on.
    To use any of the following options, open PowerShell and execute the following command with a chosen parameter:
    uproxy <parameter> <value>
    The following tables list the available parameters:
    Table 1. General
    Parameter name Description
    -collectDiagnosticData Creates a zip file containing the log files, the result of diagnostics and the server.properties file, without sensitive data (for example, LDAP admin password, RADIUS password, and so on). By default, the .zip file is created in the folder from where you run the script.
    -destinationPath
    Note: Can only be used with -collectDiagnosticData.
    Sets a destination path, where the .zip file is created.
    -editConfig Opens the server.properties file, if it is present, in the default text editor.
    -help Prints the description of the script to the console.
    Note: This is the default behaviour when no parameter is provided.
    -logLevel
    Sets the log level of LastPass Universal Proxy.
    The following values are available:
    • debug
    • info
    Important: It takes two minutes for the changes to apply. The change can take effect without manually restarting the Windows service.
    -showConfig Prints the content of the server.properties file to the console without sensitive data.
    -version Shows the LastPass Universal Proxy version.
    Table 2. Configuration tool
    -configurationTool Starts the CLI configuration tool. For more information, see Configure LastPass Universal Proxy 4.x using command line interface (CLI) on Windows.
    Table 3. Windows service
    -start Starts the LastPass Universal Proxy Windows service.
    -stop Stops the LastPass Universal Proxy Windows service.
    -restart Restarts the LastPass Universal Proxy Windows service.
    -status Prints the status of the LastPass Universal Proxy Windows service.
    Diagnostic tool
    The following tables list the parameters for the diagnostic tool. For more information, see How do I run diagnostics for LastPass Universal Proxy v4.x?.
    -diagnostic
    Starts the diagnostic tool.
