- Log in to the Pulse Secure admin console.
- Select in the top toolbar.
- In the New: drop-down menu, select LDAP Server.
- Click New Server....
- In the New LDAP Server window, set the following fields:
Name
Enter a name for your LDAP server.
LDAP Server
Enter the IP address of the LastPass Universal Proxy.
LDAP Port
1636
Backup LDAP Server
Enter if applicable.
Backup LDAP Port
LDAP Server Type
Generic
Connection
LDAPS
Connection Timeout
60
Search Timeout
60
- In the Authentication Required group box, set the following fields:
Authentication required to search LDAP
Check the checkbox.
Admin DN
Enter the distinguished name of the LDAP administrator in the following format:
CN=Admin,CN=Users,DC=domain,DC=country_code.
Password
Enter the administrator password that is set on the LDAP system.
- In the Finding user entries group box, set the following fields:
Base DN
Enter the Base DN under which the users are located, in the following format:
Filter
Enter
uid=<username>.
- After saving changes on the Server Configuration page, click Test Connection to test your configuration settings.
Results: Your Pulse Secure VPN is now configured to use LDAPS protocol for authentication.
