Pulse Secure VPN configuration for LastPass Universal Proxy
LastPass offers MFA integration with your Pulse Secure VPN using LastPass Universal Proxy.
LastPass also offers SAML integration with Pulse Secure, allowing you to use LastPass as your single sign-on identity provider. If you choose SAML integration, you can enable LastPass MFA using policies.
The described configurations are based on the following software and hardware versions:
- Pulse Connect Secure Version 9.1R3 (Build 3535)
- Pulse Desktop Client Version 9.1.R3 (Build 1313)
As a prerequisite you must complete the steps for
- downloading and
- installing LastPass Universal Proxy,
- then configuring it using the command line interface (CLI) or the server.properties configuration file.
Once you have installed and configured the LastPass Universal Proxy, you can configure your Pulse Secure VPN for authentication using the following protocols:
- LDAP, for more information on the specific steps see Pulse Secure VPN configuration for LastPass Universal Proxy LDAP protocol.
- LDAPS, for more information on the specific steps see Pulse Secure VPN configuration for the LastPass Universal Proxy LDAPS protocol.
- RADIUS, for more information on the specific steps see Pulse Secure VPN configuration for the LastPass Universal Proxy RADIUS protocol.
- LDAP on Linux, for more information on the specific steps see Pulse Secure VPN configuration for LastPass Universal Proxy LDAP protocol on Linux.
- LDAPS on Linux, for more information on the specific steps see Pulse Secure VPN configuration for the LastPass Universal Proxy LDAPS protocol on Linux.
