Nickname |
The name of the app how it appears in the Admin Console (and Cloud Apps, if your users have a LastPass password management vault) |
Role |
Custom role that you created to organize users and the permissions assigned to them |
Identity Provider (LastPass) |
https://identity.lastpass.com |
Relay State |
URL to which the service provider redirects the user after processing the SAML response |
Identifier |
These settings will depend on the app you're configuring – please refer to the SSO app's documentation, then select one of the following:
- Email (default)
- Secondary Email
- User ID
- Groups
- Roles
- Custom
SAML signature method |
Select one of the following, based on your desired encryption key length:
- SHA1 (uses 160-bit hash)
- SHA256 (uses 256-bit hash)
Signing and encryption |
Make your desired selections from the following:
- Sign assertion
- Encrypt assertion
- Sign request
- Sign response
Upload partner certificate |
Select the partner certificate you saved locally (if applicable) |
Custom attributes |
To add more custom attributes, select Add SAML attribute and choose from the following options:
- Email
- Secondary Email
- User ID
- Groups
- Roles
- Custom (associated with the SSO app)
