Regenerate key for Duo Security authentication
You can regenerate the Security key for your Duo Security users if you want to reset the MFA secret.
About this task:
Important: If you regenerate the key for Duo Security, your users cannot log in until you set up the new key in LastPass.
Before you begin:
Note: The steps outlined below must be performed by an admin of both the integration tool and LastPass Business.
Results: You regenerated the key for Duo Security.
