Require a Master Password Reprompt
You can enable the "Require master password reprompt" setting as an additional layer of security, which will require that you enter your master password in order to gain access to certain areas within your LastPass vault. This setting can be managed for individual items in your vault, or when you access an item type and/or perform certain actions via your Account Settings.
Enable setting per item
You have now enabled the
Require master password reprompt setting for your desired item.
Enable setting for item types and actions
You have enabled the
Require master password reprompt setting for your desired item types and actions.
