Reset MFA shared secrets for Google Authenticator, Microsoft Authenticator, LastPass Authenticator and Grid
    You can reset the MFA shared secrets for Google Authenticator, Microsoft Authenticator, LastPass Authenticator, and Grid users. This will invalidate their current MFA entry, delete their trusted devices and destroy their open sessions, so they are forced to log in again and re-enroll their MFA apps.
    You can clear all users' or a selected group's shared secrets, delete their trusted devices and destroy their open sessions, so they are forced to log in again and re-enroll their MFA apps.
    Note: This feature requires a LastPass Business or LastPass Teams account with administration rights.
    Reset MFA shared secrets of a group for Google Authenticator, Microsoft Authenticator, LastPass Authenticator and Grid
    About this task: You can clear the shared secrets of a selected group of users', delete their trusted devices and destroy their open sessions, so they are forced to log in again and re-enroll their MFA apps.
    Before you begin: Review the policies you have set up regarding the use of multifactor authentication options before resetting the MFA shared secrets. If any MFA is required, your users will need to go through the setup process before being able to log in to their LastPass vault. For more information about setting MFA policies, view How do I manage multifactor authentication options for LastPass Business?.
    Note: If you have not enabled any policy that requires the use of MFA, your users don't need MFA to log in.
    3. Select your account in the top right corner, then click Switch to old console.
    4. Select Groups in the left navigation.
    5. Select the group for which you want to reset the MFA shared secrets
    6. Select More options in the top right corner, then click Reset MFA shared secrets.
      Reset MFA shared secrets for groups
    7. In the pop-up window enable I understand who is impacted and what to expect after reset, then select Reset.
    8. Check the status of the background processes under the Reports > Admin activity tab. Make sure that the processes finished successfully for all users.
      You can also export the report by clicking More options > Export report in the upper right corner.
      Report of Reset MFA shared secrets
    Results: Your group's shared MFA secrets are removed, any app pairings or Grid values are invalidated, their trusted devices are deleted and their open sessions are destroyed.
    What to do next: Your users must log in again and verify their login attempt via email. If required to set up MFA by policy, they are placed into the MFA setup flow to pair their account again. Your users must also re-enable passwordless login with LastPass MFA if it was used before the reset.
    Reset MFA shared secrets for all users for Google Authenticator, Microsoft Authenticator, LastPass Authenticator and Grid as a LastPass Business admin
    About this task: You can clear all user’s shared secrets, delete their trusted devices and destroy their open sessions, so they are forced to log in again and re-enroll their MFA apps.
    Note: This feature requires a LastPass Business account with administration rights.
    Note: If you have not enabled any policy that requires the use of MFA, your users might don't need MFA to log in.
    3. Go to Advanced > Enterprise options > Multifactor options.
    4. In the Enabled multifactor options tab, select More options next to Update, then click Reset MFA shared secrets.
      Reset MFA shared secrets for all users as a LastPass Business admin
    5. In the pop-up window enable I understand who is impacted and what to expect after reset, then select Reset.
    6. Check the status of the background processes in the Reporting > Admin activity tab. Make sure that the processes finished successfully for all users.
      You can also export the report by clicking Export report.
    Results: Your user’s shared MFA secrets are removed, any app pairings or Grid values are invalidated, their trusted devices are deleted and their open sessions are destroyed.
    Reset MFA shared secrets for all users for Google Authenticator, Microsoft Authenticator, LastPass Authenticator and Grid as a LastPass Teams admin
    Note: This feature requires a LastPass Teams account with administration rights.
    4. Go to Settings > Multifactor options > Enabled multifactor options.
    5. Select More options in the Enabled multifactor options panel, then click Reset MFA shared secrets.
      Reset MFA shared secrets as a LastPass Teams account
    6. In the pop-up window enable I understand who is impacted and what to expect after reset, then select Reset.
    7. Check the status of the background processes under the Reports > Admin activity tab. Make sure that the processes finished successfully for all users.
