Restore Deleted Items and Folders
When you delete passwords, secure notes, or items from your LastPass vault, the items are sent to your Deleted Items repository where they are stored for up to 30 days from the date they are deleted. Alternatively, you can manually purge these within 30 days of their deletion date; otherwise, LastPass will permanently delete these items automatically after 30 days.
Restore a single item
If you restore an item that was located in a folder that was deleted, both the folder and the single item you selected will be restored.
- Go to https://lastpass.com/?ac=1 and log in with your username and master password.
and then click Open My Vault.
- Select Advanced Options in the navigation pane.
- Select View deleted items.
- Locate your deleted item, then click the Restore icon
in the lower-right navigation.
- When prompted, click Yes to restore your item and display it in your vault.
Restore multiple selected items
If you restore items that were located in a folder that was deleted, both the folder and your selected items will be restored.
