How do I review changes in Note history?
    You can review changes made to your Notes by viewing the Note history.
    1. When you edit your Note, you can click the History icon .
    2. Click Show to view the Note as it had appeared prior to the saved changes.
      Note:  The Note History only shows a record of the last 5 changes made to each Note.
      Dialog box showing note history
