Use RSA SecurID Multifactor Authentication
    LastPass Business supports RSA SecurID as a form of multifactor authentication for user access to their LastPass account. A second factor of authentication can protect your LastPass vault against replay-attacks, man-in-the-middle attacks, and a host of other threat vectors.
    Note:
    To get started, LastPass admins must complete the steps for enabling RSA SecurID multifactor authentication.
    About using multiple multifactor authentication options
