Use SecureAuth Authentication
You can utilize Multifactor Authentication with SecureAuth, which generates a 4-digit OTP (one-time password) code via SMS/text message or via the SecureAuth app on the user's mobile device that they can use for authenticating as they log in to their LastPass account. The SecureAuth Authenticate mobile app is available for iOS and Android.
To get started, LastPass admins must complete the steps for enabling Multifactor Authentication in the Admin Console.
Once the administration steps are complete, LastPass users can set up and use SecureAuth.
About using multiple multifactor authentication options
