Set Up Federated Login for LastPass Using Okta SSO and Active Directory
Option #2 (hybrid configuration)
LastPass Business account admins can set up and configure federated login using Okta in a few different ways so that users can log in to LastPass without ever having to create a second Master Password. Once Okta federated login is set up, LastPass Business users can log in to LastPass using their Okta account (instead of a username and separate master password) to access their LastPass vault.
Federated login using Okta can be set up in the following ways:
Option | Identity Provider | Directory Provider | Authorization Server | Account requirements |
Option #1 (standard configuration, without an authorization server) For more information, see Set Up Federated Login for LastPass Using Okta Without an Authorization Server. |
Okta SCIM |
Okta SCIM |
All of the following:
Option #2 (hybrid configuration) For more information, see instructions below. |
Okta SSO |
Active Directory |
Option #3 (standard configuration, with an authorization server) For more information, see Set Up Federated Login for LastPass Using Okta With an Authorization Server. |
Okta SCIM |
Okta SCIM |
This guide provides setup instructions for using LastPass with Okta SSO (single sign-on) as your Identity Provider (IdP) and Active Directory as your directory provider. This type of setup may be referred to as a “hybrid” configuration (Option #2).
Before you begin
Before you begin the setup process between the LastPass Admin Console and the Okta Admin portal, review important information that applies to federated users.
- Ensure you have set up the LastPass AD Connector.
- Additionally, linked personal accounts must be verified on every new device that a federated user will use for logging in to access their LastPass vault.
You are now ready to follow the step-by-step instructions indicated at the bottom of the page to set up federated login using Okta SSO as your Identity Provider and Active Directory as your directory provider. Complete all steps one by one.
F.A.Q.
For frequently asked questions, see the following articles:
- Step #1: Create a Single-Page Application for LastPass to Enable Login with Okta
- Step #2: Enable the Authorization Code Grant Type
- Step #3: Add a Company-Wide Key as a Group Claim
- Step #4: Enable CORS for LastPass
- Step #5: Set Up Okta Federated Login in LastPass with PKCE Flow
- Step #6: Provision Users to LastPass Using the LastPass AD Connector
- Step #7: Assign the User to the Single-Page Application
In this section:
