Set Up Federated Login for LastPass Using OneLogin
Federated login for LastPass Business allows users to log in to LastPass using their organization's OneLogin credentials without having to create and use a separate master password.
LastPass supports the following provisioning features:
- Create users
- Update user attributes
- Delete users
- Sync groups
Before you begin the setup process between LastPass and OneLogin, review the account requirements and limitations that apply to federated user accounts.
Account requirements
- An active OneLogin subscription
- Access to OneLogin's API Access Management feature
Note: If you don't have access to this feature or you are not sure whether or not you have access to it, contact your OneLogin sales representative for assistance.
- An active trial or paid LastPass Business account
- An active LastPass Business admin (required when activating your trial)
Note: If you have not started a LastPass Business trial, contact our Sales team at lastpass.com/contact-sales for more information.
Limitations that apply to federated users
Restriction: LastPass does not support the use of multiple domains for directory integrations and federated login, including the use of different directory instances and/or multi-domain & multi-forest configurations. Learn more about federated login limitations.
- Additionally, linked personal accounts must be verified on every new device that a federated user will use for logging in to access their LastPass vault.
You are now ready to follow the step-by-step instructions indicated at the bottom of the page to set up federated login using OneLogin. Complete all steps one by one.
- Step #1: Generate a Provisioning Token and obtain the Connection URL in LastPass
- Step #2: Add the LastPass Provisioning app in OneLogin
- Step #3: Configure the LastPass Provisioning app and enable provisioning in OneLogin
- Step #4 (Optional): Configure group synchronization between OneLogin and LastPass
- Step #5: Create login apps for LastPass in OneLogin
- Step #6: Set up OneLogin federated login in LastPass
- Step #7: Add API for LastPass in OneLogin
In this section:
