Use Smart Card Authentication
LastPass has support for Smart Card readers for computers running Windows, macOS, or Linux. Additionally, SafeSign middleware, Firefox, and Chrome support this feature. Safari and Opera can be supported by installing an additional Binary Component via the LastPass Universal Installer.
For LastPass admins, it is recommended that you complete the steps for enabling multifactor authentication in the Admin Console.
OpenSC is also supported as an alternative to SafeSign (currently only on Windows and Linux). Note that since some web browsers still run in 32-bit mode (even on 64-bit versions of Windows), you may need to install both the 64-bit and 32-bit versions of OpenSC.
- For Windows, ensure that aetpkss1.dll or opensc-pkcs11.dll is present on your system (located at C:\Windows\System32).
- For macOS, ensure that libaetpkss.dylib is present on your system (located at /usr/local/lib).
- For Linux, ensure that libaetpkss.so or opensc-pkcs11.so is present on your system (located at /usr/lib).
Please ensure that an RSA Key is present on your Smart Card. This RSA Key must be capable of encryption and decryption so that LastPass can verify your Smart Card’s security.
Step #1: Set up and configure your Smart Card in LastPass
- Insert your Smart Card into your card reader.
- Select on the Multifactor Options tab.
- Select the Edit icon
for Fingerprint / Smart Card.
- For the Type option, use the drop-down menu and select Smart Card Reader.
- For the Enabled option, use the drop-down menu and select Yes.
- When prompted, enter your master password and click OK.
- Follow the prompts to finish setting up Smart Card authentication.
- Click Update when finished.
Step #2: Log in to LastPass using Smart Card authentication
- Go to https://lastpass.com/?ac=1, then enter your username and master password and click Log In.
- In your web browser toolbar, click the inactive LastPass icon
. Enter your username and master password and click Log In.
- When prompted by LastPass, enter your Smart Card PIN to authenticate.
About using multiple multifactor authentication options
Disable authentication for a new or lost device
If your phone number has changed or the mobile device used for authentication is lost, you can disable multifactor authentication via email so that you can log in to your LastPass account.
