Step #1: Create a Provisioning Token and Capture the Connection URL for PingOne in LastPass
To begin the setup process for LastPass using PingOne, capture both the Connection URL and Provisioning Token from the LastPass Admin Console.
Before you begin: It is
required that you
enable the "Permit super admins to reset master passwords" policy for at least one LastPass admin (who is also a non-federated admin, if you are setting up federated login) in the LastPass Admin Console. This ensures that all LastPass user accounts can still be recovered (via
master password reset) if a critical setting is misconfigured or changed after the setup is complete.
Tip: Open a text editor application so that you can save the values that will be used to connect LastPass and PingOne.
The steps below are performed in the LastPass Admin Console.
You have captured both the Connection URL and Provisioning Token from the LastPass Admin Console.
