Step #1: Generate a Provisioning Token
To begin the setup process for LastPass using Okta, capture both the Connection URL and Provisioning Token from the New LastPass Admin Console.
Before you begin: It is
required that you
enable the “Permit super admins to reset master passwords” policy for at least one LastPass admin (who is also a non-federated admin, if you are setting up federated login) in the
LastPass
new Admin Console. This ensures that all LastPass user accounts can still be recovered (via
master password reset) if a critical setting is misconfigured or changed for after setup is complete.
Tip: Open a text editor application so that you can save the values that will be used to connect LastPass and Okta.
About this task: The steps below are performed in the
LastPass
new Admin Console.
Results: You have created the Provisioning Token in LastPass and saved it for later use.
