Step #2: Configure Federated Login Settings for PingFederate in LastPass
Configure your federated login settings for PingFederate in LastPass.
Before you begin: If you have already installed the LastPass Active Directory Connector, you must stop the service and exit the ADC application. You will need to start it at a later step.
Next article:
Step #3: Install the LastPass Active Directory Connector
