Step #6.2: Configure OAuth Client ID for iOS
    You can configure the OAuth Client ID for the iOS.
    1. Click Credentials in the left navigation menu.
    2. Click +CREATE CREDENTIALS and select OAuth client ID.
    3. Set the Application type to iOS.
    4. Enter LastPass iOS in the Name field.
    5. Enter com.lastpass.ilastpass in the Bundle ID field.
    6. Click CREATE.
    7. Copy the Client ID in the Credentials window to a text editor application as you will need it in a later step.
