Step #1: Set up and configure RSA SecurID in LastPass
    Set up and configure RSA SecurID so that you can employ RSA SecurID as your second factor of authentication.
      • In your web browser toolbar, click the LastPass icon active LastPass icon and select Open My Vault.
    3. Select the Multifactor Options tab.
    4. Select the Edit icon Edit option for RSA SecurID.
    5. For the Enabled drop-down menu, select Yes.
    6. For the Permit Offline Access drop-down menu, choose one of the following:
      • Select Allow if you want to allow access to LastPass even when you are offline. This will store an encrypted vault locally so you can log in without using multifactor authentication in case of a connectivity issue.
      • Select Disallow to prevent offline access, which requires the use of multifactor authentication and to be connected to the Internet when using LastPass.
        Important: If this option is selected and you are not connected to the Internet and/or https://lastpass.com is not available, you will be unable to access your vault. Learn more about offline access.
    7. When finished, select Update.
    8. Enter your master password and click Continue.
      RSA SecurID settings in Multifactor Options
    9. When prompted, enter the verification code displayed in the RSA SecurID app on your mobile device, then click OK.
    10. Click OK on the confirmation message.
    Results: You have enabled RSA SecurID for multifactor authentication to protect your LastPass vault.
