Step #3: Configuration & Testing
Review the various configurations available for LastPass as the options will depend on the type of environment you have in your organization.
Summary
- Review the available endpoints and determine which resources you want to protect with multifactor authentication via the LastPass Authenticator app.
Note: If you are interested in federated login using third-party Identity Providers, please see Which Identity Providers are supported for LastPass Federated Login?
- Multifactor authentication via the LastPass Authenticator app (LastPass MFA) will serve as an additional security layer for your protected endpoint.
- During your test group creation for initial testing, focus on creating a small testing group that includes people from multiple departments across your organization for a more accurate picture of end user experience. Additionally, create a department or group of "Super Admins" that will have permissions assigned to assist others during the full rollout (e.g., resetting master passwords for users).
Planning
Explore Admin Console Features
- Determine which endpoints you want to protect with multifactor authentication via the LastPass Authenticator app (LastPass MFA), which can include any of the following MFA Apps:
- Workstation MFA (for Windows and Mac workstations)
- AD FS
- Azure AD
- Universal Proxy/VPNs
- Create user groups and assign users.
- Assign users and groups to admin levels based on permissions you want to give them.
Explore Integrations with Directories and/or SSO Providers
- Determine whether you have an existing SSO provider you plan to integrate with for protecting apps.
- Review our resources for directory integrations:
Set Up Your Test Group (Super User Pilot Group)
- Define Test Group participants.
- Inform Project Team of Test Group launch date and scope.
- Define project milestones and success measurements for Test Group
Testing by the Project Team
Parent article:
LastPass MFA Deployment Guide
Previous article:
Step #2: Provisioning
Next article:
Step #4: Policies & Reports
