Step #6.3: Configure OAuth Client ID for Android
    You can configure the OAuth Client ID for the Android.
    1. Click Credentials in the left navigation menu.
    2. Click +CREATE CREDENTIALS and select OAuth client ID.
    3. Set the Application type to iOS.
      Note: Selecting iOS for the Android platform is required for the function to work correctly.
    4. Enter LastPass Android in the Name field.
    5. Enter com.lastpass.lpandroid in the Bundle ID field.
    6. Click CREATE.
    7. Copy the Client ID in the Credentials window to a text editor application as you will need it in a later step.
