Step #3: Configure your LastPass Business federated login settings
If you have already installed the LastPass Active Directory Connector, you must stop the service and exit the ADC application. You will need to start it at a later step.
About this task:
Now that you have obtained all of the necessary information, you can configure your LastPass Business Federated Login settings as follows:
Parent article:
Set up simplified federated login for LastPass using AD FS
Next article:
Step #4: Install the LastPass Active Directory Connector
