Step #5: Create login apps for LastPass in OneLogin
Create app integrations for LastPass in OneLogin, and configure them to enable login to LastPass with OneLogin credentials.
About this task: The steps below are performed in OneLogin.
You will be creating the following login apps:
- Desktop app
- Android app
- iOS app
- Web app
Perform the following steps from start to end for all apps, one after the other. The procedure is the same for all apps with some key differences. The differences are called out specifically in the steps that follow.
Results: You have created four different login apps and each of them should be displayed on the
page.
Parent article:
Set Up Federated Login for LastPass Using OneLogin
Next article:
Step #6: Set up OneLogin federated login in LastPass
