Step #4: Enable Provisioning to the LastPass Provisioning Application in Okta
    Configure the LastPass provisioning app in Okta to provision users from Okta into LastPass.
    1. On the Provisioning tab, select To App in the left navigation.
    2. Next to the Provisioning to App label, click Edit. Choose one from the following options:
      • If you do not have any existing users and/or groups in LastPass currently, check the boxes to enable the following settings:
        • Create Users
        • Update User Attributes
        • Deactivate Users
      • If you do have existing users and/or groups in LastPass currently, check the box to enable only the following setting:
        • Deactivate Users
          Note: If you only selected Deactivate Users at this time, you will need to come back to this step and check the boxes to enable the Create Users and Update User Attributes settings after you have assigned all of your users and/or user groups then pushed all of your groups (after Step #5: Assign Users to the LastPass Provisioning Application Step 6).
    3. Click Save.
