Step #4 (Optional): Configure group synchronization between OneLogin and LastPass
In some cases, you may want to segment your users into groups to sync between OneLogin and LastPass. You can sync a group from LastPass to your OneLogin app, and assign this group directly to your users in the OneLogin admin portal to assist with your user administration.
About this task:
Important: Group provisioning between OneLogin and LastPass is not available.
Note: There is no direct group-to-group sync available between OneLogin and LastPass. However, you can map a group folder from LastPass to OneLogin and add your users and/or groups to it. The sync is not automatic and you must manually refresh the configuration.
- Enable group sync in OneLogin.
- Select the Parameters tab, then Groups.
Result: The Edit Group Fields pop-up window appears.
- Activate the flag Include in User Provisioning, then select Save.
- Create a group in LastPass.
- Create a group in OneLogin.
- Select in the top navigation.
- Click New Group.
- Provide a name for your group.
- Select your policy of choice from the Security policy drop-down menu.
- Click Save.
- Sync the group from LastPass to OneLogin.
- Go back to your LastPass Provisioning app in the OneLogin admin portal.
- Select the Configuration tab.
- Toggle the API status from "Enabled" to "Disabled", then back to "Enabled", using the Disable and Enable buttons.
- Check whether the group that you created in LastPass is present in OneLogin.
- Click the drop-down menu.
Result: The group synced from LastPass should be present.
- At this point, you have the option to set a default group from LastPass where your users will be synced to. However, you also have the option to leave the Value field unselected and configure a group for each of your users individually:
- Select in the top navigation, then select a user.
- Select the Applications tab.
- Select the LastPass Provisioning app.
- Under Groups, use the drop-down list to select the group that you synced from LastPass.
- Click Add.
- Click Save.
- Click Save User.
Parent article:
Set Up Federated Login for LastPass Using OneLogin
Previous article:
Step #3: Configure the LastPass Provisioning app and enable provisioning in OneLogin
Next article:
Step #5: Create login apps for LastPass in OneLogin
