System Requirements for Users
    LastPass is supported on the Windows, Mac, Linux, and mobile platforms – so all of your data is stored in a centralized place and is accessible from anywhere, anytime! You can use the LastPass browser extensions, desktop apps, or mobile apps. You can also learn more about virtual environments and the binary component.
    To get started, you can create an account then downloading and installing LastPass for all of your devices.
    Note: LastPass is not supported on sites that run in IE mode.
    Use the LastPass browser extensions
    In order to download and use the LastPass browser extensions from your desktop, your system must meet the following requirements:
    Requirements for Web Browser Extensions Notes & Documentation
    Operating Systems
    • Windows 8.1 or later*
    • The two (2) most recent major macOS versions with a 64-bit processor required
    • Linux
    • Chrome OS
    n/a
    Web Browsers
    • The two (2) most recent versions of the following web browsers:
      • Google Chrome
      • Mozilla Firefox
      • Microsoft Edge
      • Safari
      • Opera
    The LastPass IE web browser extension only receives security updates, compatibility fixes, and technical support, but does not receive new LastPass feature enhancements as it is currently in maintenance mode per Microsoft. Please see https://www.microsoft.com/en-us/microsoft-365/windows/end-of-ie-support for more information.
    Internet Connection
    • An internet connection with 1 Mbps or better (broadband recommended)
      Note: ICMP is a required protocol used by LastPass to ping lastpass.com to verify end-to-end connectivity. Additionally, communication with lastpass.com is through HTTPS using port 443 withTLS 1.2.
    n/a
    *For installing the LastPass Universal Installer, .NET Framework 4.52 or later is required on Windows 8.1 or later.
    Use the LastPass desktop app
    In order to download and use the LastPass for Windows Desktop application on your desktop, your system must meet the requirements below.
    Notice: LastPass discontinued support for the legacy Mac App for desktop as of February 29, 2020.
    Requirements for Desktop Apps Documentation
    Operating Systems
    Internet Connection
    n/a
    Use the LastPass mobile apps
    In order to download and use the LastPass mobile apps, your mobile device or tablet must meet the requirements listed in the table below.
    The mobile apps are:
    • LastPass app – Password management app for iOS and Android
    • LastPass Authenticator app – Authenticator app for iOS and Android
    Requirements for Mobile Apps Documentation
    Android Mobile Operating System
    • Android OS 13 or later
      • Access to the Play Store app is also required
    iOS Mobile Operating System
    • iOS 14.0 or later
    • iOS 15.0 or later
    Internet Connection 3G (or better) or Wi-Fi n/a
    About virtual environments
    LastPass is not currently supported for use in virtual environments.
    Restriction: Please note that LastPass Support does not provide technical support for LastPass in virtual environments.
    About the binary component
    The binary component is included in the LastPass Universal Installer for Mac and Windows, and is supported on the Chrome, Firefox, Safari, and Opera, desktop web browsers via the web browser extension. Learn more about the binary component.
