Open the Cisco AnyConnect Configuration Wizard and send a test authentication request:
In the Servers in the Selected Group area, select the server you want to test
Click Test, in the right menu bar.
Result: The Test AAA Server dialog box appears for the selected server.
Select the Authentication radio button.
In the Username field, enter your username, which should be the same as the sAMAccountName field value in the Active Directory for the test user.
In the Password field enter your password, which is the password stored in the Active Directory for the test user.
Click OK.
Result: The Adaptive Security Appliance (ASA) sends an authentication test message to the server. An Information dialog box appears, showing if the test failed or was successful.
If the test is successful, everything is set up correctly in the VPN server, LastPass Universal Proxy and LastPass Authentication Server.
Test the login from Cisco AnyConnect Secure Mobility Client:
