Use Toopher Authentication (not available for new users)
Toopher is an authentication application that is no longer accepting new users due to its acquisition by Salesforce. Current users can still use Toopher while Salesforce continues to support it.
For LastPass admins, it is recommended that you complete the steps for enabling multifactor authentication in the Admin Console.
Step #1: Set up and configure Toopher for your LastPass account
and select Open My Vault.
- Select the Multifactor Options tab.
- Select the Edit icon
for Toopher Authentication.
- For the Enabled drop-down menu, select Yes.
- For the Permit Offline Access drop-down menu, choose one of the following:
- Select Allow if you want to allow access to LastPass even when you are offline. This will store an encrypted vault locally so you can log in without using multifactor authentication in case of a connectivity issue.
- Select Disallow to prevent offline access, which requires the use of multifactor authentication and to be connected to the Internet when using LastPass.
Important: If this option is selected and you are not connected to the Internet and/or https://lastpass.com is not available, you will be unable to access your vault. Learn more about offline access.
- When finished, select Update.
- Enter your master password, then select Continue.
- Open the Toopher application on your mobile device, then tap Pair this device with a Toopher-enabled service. This will generate a unique 2-word pairing phrase.
- Back on your web browser, enter the unique pairing phrase and click OK.
- On your mobile device, tap Allow on the Pairing Request screen.
- Back in your web browser, click OK on the confirmation message that your settings have been successfully updated.
Step #2: Log in to LastPass using Toopher authentication
You can log in and access your LastPass vault from a desktop or mobile device.
Log in from the desktop and authenticate
Log in from a mobile device and authenticate
About using multiple multifactor authentication options
Disable authentication for a new or lost device
If your phone number has changed or the mobile device used for authentication is lost, you can disable multifactor authentication via email so that you can log in to your LastPass account.
