Users will be synced from the directory to both the Password Management and SSO & MFA Admin Consoles. Editing users is available on both Admin Consoles, and any updates made on either side will be synced. Deleting a user in either of the Admin Consoles will also be reflected on the other.
- Select MFA or SSO & MFA in the left navigation.
- To add users, go to .
Fill out the required fields, including the following:
- Username
- First Name
- Last Name
- Click Save when finished.
Result: A new activation email is sent to the user with instructions on how to activate passwordless login.
- Optional: To edit users, click Users.
Search for a user in the search box and click on a user to edit that user's information.
Action in LastPass |
Instructions |
To edit user attributes |
Click the Attributes tab. |
To see the user's information |
Click Entitlement or History. |
To view and lock the user's device |
Click the Devices tab. |
To edit user's admin privilege |
Expand the Advanced section. |
If the user is required to use PKI for authentication |
Click Certificate and upload the user's PKI certificate. |
To resend the activation email to a user |
Click Resend Activation. |
To suspend the user's access |
Click Suspend Access. |
To delete a user |
Click Delete. |
To see a user's privilege level |
Click the Privileges tab. |
To see the policies and applications of a user |
Click Assigned Policies and Assigned Applications |
For instructions on editing policies, privileges, and applications, check managing policies page and SSO applications.
Please note that to automate the process of importing users and provisioning LastPass accounts, you can use the directory integration feature.
