What are admin levels?
LastPass includes preset admin levels and each level has a preset configuration to choose from. Each level grants specific functionality so you can give appropriate levels of access to LastPass In addition, it is also possible to define custom admin levels with only a limited or a wider range of permissions (depending on your use case).
User
- Access to their own vault and folders shared with them
- Feature usage and access limited by policies through LastPass
Legacy Helpdesk Admin
The least-privileged admin tasked with day-to-day management of LastPass and supporting employees with their IT questions. You can restrict their level of Admin Console access by enabling the Grant limited access to Admin Console policy.
- Only allows Reset master password for users but not full admins (also requires enabling the "Permit super admins to reset master passwords" policy)
- Only allows the following actions:
- Disable multifactor authentication for users
- Management of the Users page
- Management of the Groups page
- Only allows access to managed companies (excludes permissions 1-4) – For more information, please see What are managed companies for LastPass Business?
Helpdesk Admin
- Reset master password for users but not full admins
- Destroy user sessions
- View-only access of Users page
- View-only access of Groups page
- View-only access of Admins page
Admin
These are your IT managers and team leads that have access to all areas of the admin dashboard for ability to deploy, configure, and manage LastPass, such as user provisioning, policy setting, and much more. Be sure to protect admin LastPass accounts by enabling multifactor authentication. Admins have all of the same permissions as the Legacy Helpdesk Admin (listed above), as well as:
- Access to all areas of the Admin Console
- Ability to enable/disable policies
- Add or remove users
Super Admin
You’ll likely only have one or two super admins who have the most privileged access to LastPass, particularly for emergency scenarios. Super admins have all of the same permissions as admins (listed above), as well as:
- Master Password reset on any user's vault
- Access to all shared folders across the company
To add a super admin, follow the procedure described in How do I view and assign admin levels in the new Admin Console?.
Another way to add a super admin is to assign the following policies to a selected existing admin on the
page:- Permit super admins to reset master passwords
- Permit super admins to access shared folders
Custom Admin
Custom admins are created with specific customized permissions in the new Admin Console (much like roles in the old Admin Console). This is useful when you want to enable someone in your organization to perform certain actions that require special permissions but you don't want them to become an admin with a wide range of admin rights. For example, you would like someone to be able to view reports but you do not want them to be able view and modify users/groups.
- Adoption Dashboard
- Users
- Groups
- Directories and federated login
- User-level multifactor authentication
- Reports
To add a custom admin, follow the procedure described in the following article: How do I assign and edit custom admins in the new Admin Console?
For those who migrate their roles (created in the old Admin Console) to custom admin levels, the following article has useful information: How do I migrate a role to a custom admin level?
