What is LastPass Workstation Login?
Workstation Login for LastPass enables users to authenticate into their workstations, or work computers, using biometric authentication (face recognition or fingerprint identification) via the LastPass Authenticator.
As opposed to entering a traditional username and password to log into their workstation,
Workstation Login supports the following login methods (if policies permit) when logging in to a Windows or Mac workstation:
- Using face recognition or fingerprint identification or a PIN Code (biometric authentication) to authenticate in the LastPass Authenticator.
- Using a One-Time Passcode, which is generated within the LastPass Authenticator on a registered device.
